Björne
2 years agoWhy does aoc set ii to 6 when I use high clock frequencies?
I have a simple toy that I want to run at 1000 MHz kernel that doesn't do much: __attribute__((uses_global_work_offset(0))) __attribute__((max_global_work_dim(0))) __kernel void netsim( __global...
BoonBengT_Altera
Moderator
2 years agoHi @Björne,
Thanks for confirming the tools involved, is there any references design with BSP that you are referring to?
Also what are the compilation involved? This would be helpful information for us to try the mention design.
Hope to hear from you soon.
Best Wishes
BB
