Björne
2 years agoWhy does aoc set ii to 6 when I use high clock frequencies?
I have a simple toy that I want to run at 1000 MHz kernel that doesn't do much: __attribute__((uses_global_work_offset(0))) __attribute__((max_global_work_dim(0))) __kernel void netsim( __global...
BoonBengT_Altera
Moderator
2 years agoHi @Björne,
Thank you for posting in Intel community forum and hope all is well.
To help us understand the situation better, may I know what are the tools and also hardware that you are using in this situation? Any error message that you are seeing?
Also is there any references design that you are referring?
Hope to hear from you soon.
Best Wishes
BB
- Björne2 years ago
The hardware is Agilex 7 F-Series. The software is aoc Version 21.2.0 Build 67.4 Pro Edition. No error messages or anything like that. I know 1000 MHz is much for the fpga but I'm seeing the same issue even with 700 MHz which the fpga should be able to handle.
