User1582192733150209
6 years agoWhich part of design example eth_e2e_e10 based on platform designer
Hello Sir?Madam I am running the eth_e2e_e10 design example now. I have a IP upgrading issue now . When I open the Quartus pro GUI in linux, and open the dcd.qpf project , system reminder to u...
MEIYAN_L_Intel
6 years agoHi,
I tested on the Quartus Prime Pro v17.1.1 software as recommended in the document.
According to https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2017/why-does-qsys-pro-hang-at-initializing-qsysipc-bridge.html, it might be cause by machine load.
You may need to try go to the Quartus menu: Assignments > Settings, then on the left panel select the IP Settings and on the right panel set the "Maximum Platform Designer memory usage" to the max value.
For you information, you could use the task manager to close the Platform Designer UI.
