What is the max total current output/sink about all pins of Cyclone IV ?
- 5 years ago
The maximum IOH/IOL Current Strength for IO Standard 3.3-V LVTTL is 8mA. There is no limitation mentioned in our document but the programmable current strength setting has an impact on the amount of DC current that an output pin can source or sink. Determine if the current strength setting
is sufficient for the external resistive load condition on the output pin. Yes, and as long as you follow the guideline in the handbook your device should be fine.
