Henry's avatar
Henry
8 years ago
what is memory spec in PAC?
I am trying to customized BSP for PAC, however I can't find emif parameter setting for PAC.
Is PAC use micron DDR4-CL16-2400-4GB x 2 and operating frequency at 2133MHz?
1 Reply
  • Abe's avatar
    Abe
    The PAC board has :
    8GB Double Data Rate 4 (DDR-4) Memory Banks with error correction code (ECC)
    (2 banks) operating at 2133 Mbps. There are two banks, each of 4 GB capacity.
    • The memory width is 64 data bits plus 8 ECC bits
    • 1 Gb (128 MB) Flash – for use with the FIM
    You have to use the Intel PAC , FIM and related software to develop for this board. You may not be able to use this board as a standalone FPGA development kit. It is only meant for PAC functions.
