Weird memory usage on fpga
- 3 years ago
The 8 GB you're talking about is the global memory size, and that doesn't seem to be the problem here. The problem is that you are exceeding the on-chip BRAM blocks available on your FPGA, which is not 8 GB. Assuming that you are using an Arria 10 or Stratix 10 device, the BRAM is an order of Mega Bytes and way less than 8 GB In addition, you also have much more DSP usage and not just memory. When I saw your code, you had excessive loop unrolling in the design exceeding your hardware usage. Your loops over "P" or "M" like this one (for (int jway = 0; jway < P; jway++) ) cannot be fully unrolled for your FPGA device. Fully unrolling this loop means you need 4096 instances of this loop in parallel, replicating all the loop body, including memory and DSP. For instance, a floating point multiplication within this loop will require 4096 DSP slices for this single unrolling. But you have several full-unrolled loops.
Also, the compiler may implement a cache for your memory accesses using BRAM blocks. Your unrolling might explode the memory usage as well.
You need to specify your unrolling factor and tune it so that the design can fit into the FPGA device. You can remove all the unrolling first to see how it fits, and then optimize your design by tuning the unrolling factor.
Daouda
i need your project details means are working on your own design or some example one?
if it's possible to share your project files share. it helps to identify the issue.
- murrtank3 years ago
https://jupyter.oneapi.devcloud.intel.com/user/u166468/doc/tree/Martin's%20folder/GEMM
I forgot to reply to your answer. Hope this works!
