Variable latency for HLS streaming interfaces
- 5 years ago
Hi @pavlovconst,
Thank you for posting in Intel community forum and hope all is well.
For the concept pipeline for hardware design, you can refer to the best practice guide, it has some explaining there.
Another useful section that helps explain on conditional statement can be found in the page #25 in the link above.
Hope that clarify your doubts.Best Wishes
BB
Due to the pipelined nature of the circuits generated by the compiler, all if-else statements are implemented as two (or more) same-latency paths with a multiplexer at the end; it is not possible to pipeline variable-latency operations. The only way to achieve what you want is to write your code in some way that the compiler would not pipeline the part of the code that encompasses the if-else statement; putting whole loops or different function calls on the two sides of the statement can sometimes achieve this.
- pavlovconst5 years ago
@HRZ Thanks for the answer
@HRZ написал (-а):
I wonder if this is possible by any means? Can you suggest some example?
Is there any documentation on what code constructs always get pipelined, and which ones don`t?
In my tests, I`ve never seen variable latency in the reports, unless MM interfaces get involved...
