Valgrind fails to run Intel FPGA OpenCL design examples on Arria-10
Please make sure that you have set the environment variables correctly.
Please compare the previous working values of environment variables and current one,
for example variables like CL_CONTEXT_EMULATOR_DEVICE_ALTERA should be properly set.
Thanks and Regards
Anil
I tried to keep both env variables Altera & Intel but no change.
strace tool shows libnalla_pcie_mmd.so is being opened multiple times unlike without valgrind run.
Any change is expected below lines of board_env.xml or board_env.icd file?
<mmdlib>%b/linux64/lib/libnalla_pcie_mmd.so</mmdlib>
<linkflags>-L%b/linux64/lib</linkflags>
<linklibs>-lnalla_pcie_mmd</linklibs>
<utilbindir>%b/linux64/libexec</utilbindir>
Please keep posted if you managed to run Valgrind test on FPGA (not emulator) for any SDK version beyond 16.1, best if you have tested 385A card.
Atul
