Atul_Ghalame
5 years agoValgrind fails to run Intel FPGA OpenCL design examples on Arria-10
Hi all,
I'm trying to run Intel's FPGA OpenCL design examples on Arria-10 card. I've been using SDK environment 16.1 so far and it showed memory leak with valgrind tool. So we decided to upgrade ou...
AnilErinch_A_Intel
5 years agoHi,
Please make sure that you have set the environment variables correctly.
Please compare the previous working values of environment variables and current one,
for example variables like CL_CONTEXT_EMULATOR_DEVICE_ALTERA should be properly set.
Thanks and Regards
Anil
Atul_Ghalame
5 years agoHi,
Thanks for your suggestion. I'll to ensure env variables are passed to valgrind and how it worked for previous version.
I'm running .aocx compiled on board and not the emulator mode, so could you please mention relevant variable I should check.
What does 'MMD ERROR: Unable to find an unused signal number' indicate?
strace command on valgrind shows 'aocl-pro-rte/host/linux64/lib/tls/x86_64/libc.so.6' being used. Any device specific library not set properly?
Kind regards,
Atul
