I haven't seen this type of error before. Do you compile the design using the Quartus tool?
If so, could you try to reinstall Quartus and compile again? If issue persists, kindly help to share your design (preferable .qar file) to duplicate the error.
Richard Tan
Richard,
I am using the Intel Devcloud to compile the design (I cannot re-install Quartus). I have multiple files that I compile and link. I use the following commands:
dpcpp -fintelfpga -I /home/u50480/gsl/include -c -o file1.o file1.cpp
dpcpp -fintelfpga -I /home/u50480/gsl/include -c -o filen.o filen.cpp
To link I use the following command:
dpcpp -rdynamic -fintelfpga -Xshardware -o executable_file_name file1.o ... filen.o
It seems that the error is happening on the nodes with S10 oneAPI cards. I compiled the same design on compute Only nodes (Which by default compiles for Arria10 ) and the compile finished without errors. I am not sure as of now if this has to do with just the nodes that I am compiling on or if this happens when I target S10 FPGA. I am trying to figure out how to compile on compute only nodes and target S10 Cards. This hopefully will let me know if this an install issue on some servers of if it has to do with targeting S10 Cards.
Gil.
- RichardT_altera5 years ago
I am sorry to say that I have no knowledge on this but rest assured, this case will be handled by one of my colleagues who will help you on this issue.
Richard Tan
