BZimm4
7 years agoUsing Questa Sim instead of IntelFPGA Starter Edition to build simulations
To whom it may concern: We have a correctly licensed version of Questa Sim V10.7d(64 bit) and are trying to build the dma_afu simulation using Questa Sim instead of the built in Intel FPGA Starte...
MuhammadAr_U_Intel
Contributor
7 years agoHi Bryan,
Are yuo using acceleration stack version 1.0 or 1.1 ?
Thanks for the update. Here are few things I can take as a feedback from this thread.
1. Removal of depreciated '-novopt' option from the script
2. Add missing library 'altera_mf_ver' to the simulation script in vsim command.
As for the library compilation, I believe you are referring to an outdated page, you should be referring to Quartus Prime handbook on simulation library compilation. Ref below.
https://www.intel.com/content/www/us/en/programmable/documentation/gft1513990268888.html#mwh1409960618998
For our IP simulation setup, Library compilation steps are generated as part of simulation setup script, encapsulated to bypass for Modelsim Intel Edition and executed for Modelsim SE/PE, I can request team to make generate the library compilation script as part of make file generated in AFU simulation flow.
Arslan
