BZimm4
7 years agoUsing Questa Sim instead of IntelFPGA Starter Edition to build simulations
To whom it may concern: We have a correctly licensed version of Questa Sim V10.7d(64 bit) and are trying to build the dma_afu simulation using Questa Sim instead of the built in Intel FPGA Starte...
MuhammadAr_U_Intel
Contributor
7 years agoHi,
I am looking into this case. Going through the details you shared you are following correct steps to simulate with Questasim. I Couple of questions.
- You mentioned about script to compile the verilog/ vhdl libraries (verilog-library-setup.tcl ) that were outdated, can you point me where these scripts/ steps are located in documentation ?
- Error for 'scfifo' not defined is an indication that either library is not compiled, or compiled but not specified in vsim command. Please share the log file that shows this Error along with the vsim command.
- Lastly I understand you are able to make sim work, is it correct ?
Arslan
