AAmor
7 years agoUsing A10 PAC BSP with OpenCL SDK 18.1
Hi, I am having trouble compiling some of our kernels for our a10 PAC device using OpenCL SDK 17.1. (The compilation processes hangs for 16 hours and then crashes with no explanation). We managed, h...
HRZ
7 years agoThe process is failing during fitting, likely because your kernel is too large to fit on the device. I can give you a more concrete answer if you attach the complete "quartus_sh_compile.log" file from the compilation folder.
