Using A10 PAC BSP with OpenCL SDK 18.1
Hi, @FJumaah
Thank you for your support. I've made the changes you suggested on my environment variables. The building process is working properly for small kernels, but for larger one I keep getting the error message bellow at the end of the compilation. I wanted to be sure if its a kernel or environment problem.
Thank you again for your help.
"Compiler Warning: addpipe in board_spec.xml is set to 1 which is no longer supported
Compiler Warning: global memory pipeline stage is now implemented in BSP instead
aoc: First stage compilation completed successfully.
Compiling for FPGA. This process may take a long time, please be patient.
Error: An error occurred during placement
Error: Quartus Prime Fitter was unsuccessful. 1 error, 594 warnings
Error (293001): Quartus Prime Fitter was unsuccessful. 3 errors, 594 warnings
Error (23031): Evaluation of Tcl script a10_partial_reconfig/flow.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 8 errors, 2776 warnings
Error: Compiler Error, not able to generate hardware"
