Use oneMKL with FPGA
Hi @jfra1397,
Greetings and noted with thanks for the updates, from the explanation below understood that one of the challenges are optimizing the codes, for that we do have full scale guide available below:
- https://www.intel.com/content/www/us/en/docs/oneapi/optimization-guide-gpu/2023-0/overview.html
This guide consist various are to look at for oneAPI programs optimization by guiding us to understand the report and next steps to optimize them.
As for the second challenges faced on device not support, do you have the link to the oneMKL references design you are referring to? Based on the error, I would suspect that the nodes you are working on does not have the right hardware, hence refer to the references design on the required hardware and access the node with the required hardware might be able to solve that.
Hoep that clarify
Best Wishes
BB
