jfra1397
3 years agoUse oneMKL with FPGA
Hello everyone,
I'm currently working on optimizing my code using the BLAS Level 1 and Level 2 libraries of the Intel Math Kernel Library (MKL) on an FPGA in the DevCloud environment. However, I'm...
BoonBengT_Altera
Moderator
3 years agoHey @jfra1397,
Noted and appreciate the details of the errors.
Based emulation message that shown would suspect there is a code issues where error can be seen throwed in the main.
If you do not mind me asking where did you get the codes from, do you have a references design that you are referring to?
Hence would suggest the following recommendation to try on:
1) If you desire to run emulation or hardware compile, please ensure the node selected in devcloud are with correct hardware. You can do so by running the 'pbs_nodes' command.
2) Would suggest to look into the references design below as it will be a good start to compile oneAPI design for FPGA:
Hope that clarify.
Best Wishes
BB
