RJimé1
6 years agoUse old versions of AOC in Devcloud (CL_INVALID_BINARY)
Hello, The new 20.1 version of AOC is now the default one in Devcloud. Although it works like a charm I still need to use the old version (19.3) of the compiler because my solution was designed arou...
Lawrence_L_Intel
6 years agoThere are two versions of Acceleration Stack 1.2 that uses Quartus version 17.1.1 and Acceleration Stack 1.2.1 that uses Quartus version 19.2.0 . Other versions are not supported and as mentioned the board needs to be flashed with the appropriate board support package (BSP). Hope you can find a workable solution with that in mind.
