RJimé1
6 years agoUse old versions of AOC in Devcloud (CL_INVALID_BINARY)
Hello, The new 20.1 version of AOC is now the default one in Devcloud. Although it works like a charm I still need to use the old version (19.3) of the compiler because my solution was designed arou...
KennyT_altera
6 years agoIf you follow https://github.com/intel/FPGA-Devcloud/tree/master/main/Devcloud_Access_Instructions#devcloud-access-instructions, in the tools_setup, it should have an option for u to select different AOC compiler. But seems like it is not the case. I will get back to you on this.
