NickM
6 years agoUse FPGA DRAM with OneAPI
Is there a way to specify that the private memory in the FPGA use DRAM instead of SRAM?
HRZ
6 years agoAny buffer that gets passed to the kernel as a pointer and gets explicitly allocated in device DRAM using the appropriate APIs on the host will be in FPGA DRAM, everything else will be allocated using FPGA on-chip memory.
