URGENT Customer failure analysis request MPN 10AX115N4F40E3VGAB , ADV-5050535001 ,11pcs
Please support with this issue.
Component information:
Part Number |
ADV-5050535001 |
Description |
IC LOGP FBGA1517 10AX115N4F40E |
Manufacturer |
ALTERA |
MPN |
10AX115N4F40E3VGAB |
QTY |
11 pcs |
Serial Number |
FE05325; FE05312; FE05326; FE053B8; FE052FD; FE05406; FE0581A; FE05816; FE05819; FE05824; FE05818; FE05812; FE05813; FE0582C; FE05817. |
DC |
2031, 2037, 2125, 2113 |
Problem analysis:
- These units failed Base Component Test – Verify BIST on clock devices 0,4, 5, 6 and 7 due to faulty BGA’s.
- Prior to BGA replacement, all cards were sent to x-ray inspection and there were no soldering issues found.
- Each BGA received a 7 digit code in order to trace them after re-balling.
- All faulty BGA’s were re-balled and placed on different units, but the defect was the same.
- After BGA replacement, the units passed all tests.
- ADVA R&D’s response regarding this matter is that the failing FPGAs have defective transceivers working marginally.
Test result:
Failed Base Component Test - Verify BIST: Clock DEV
Error message:
BGA Marking |
SN of failed unit |
Error message |
Min |
MAX |
Test result |
FE052FD |
FA72204102115 |
Verify BIST: CLOCK DEV 5 |
PASS |
PASS |
FAIL |
FA72204801152 |
PASS |
PASS |
FAIL |
FE05406 |
FA72205200135 |
Verify BIST: CLOCK DEV 6 |
PASS |
PASS |
FAIL |
FA72212703919 |
PASS |
PASS |
FAIL |
FE0581A |
FA72213801459 |
Verify BIST: CLOCK DEV 0 |
PASS |
PASS |
FAIL |
FE05816 |
FA72213300463 |
PASS |
PASS |
FAIL |
FE05819 |
FA72214404421 |
PASS |
PASS |
FAIL |
FE05824 |
FA72214604312 |
Verify BIST: CLOCK DEV 4 |
PASS |
PASS |
FAIL |
FE05818 |
FA72212804851 |
PASS |
PASS |
FAIL |
FE05812 |
FA72214602031 |
PASS |
PASS |
FAIL |
FE05813 |
FA72214508077 |
Verify BIST: CLOCK DEV 7 |
PASS |
PASS |
FAIL |
FE0582C |
FA72214406658 |
PASS |
PASS |
FAIL |
FE05817 |
FA72213801436 |
PASS |
PASS |
FAIL |
Ionela
1 Reply
- Zawani_M_Intel
Dear Ionela,
Thank you for using Intel FPGA Community Forum.
The case will be continued support via private email.
Thanks!
Wani
