JButt5
7 years agoUnexpected low Kernel Clock Frequency
I'm working on an OpenCL kernel targeting a Cyclone V SoC that should process a continuous real-time sample stream at a sample rate of 16 MHz, which requires a certain kernel clock frequency so that ...
- 7 years ago
You seem to be using a custom-made BSP with multiple custom I/O channels; your critical path very likely lies in your BSP. You can try compiling an empty OpenCL kernel to see what operating frequency you will get. If what you get is still in the same range, then your critical path is in the BSP and you should optimize your BSP.
HRZ
7 years agoYou seem to be using a custom-made BSP with multiple custom I/O channels; your critical path very likely lies in your BSP. You can try compiling an empty OpenCL kernel to see what operating frequency you will get. If what you get is still in the same range, then your critical path is in the BSP and you should optimize your BSP.
