Understanding Avalon-MM master in HLS generated code.
Avalon Conduit Interface is an interface type that accommodates individual signals or groups of signals that do not fit into any of the other Avalon types. You can
connect conduit interfaces inside a Platform Designer system. Alternatively, you can export them to connect to other modules in the design or to FPGA pins.
Thank you for your response. But my question was about the conduit generated for the Avalon-MM master interface for an HLS component in particular, not conduits in general. If my understanding is correct, Avalon-MM master interface is supposed to control an Avalon-MM slave, but in this case (i.e., defining an Avalon-MM master interface as an input argument for an HLS component), there's also a conduit with the same name as the master in the IP generated for the component. I wanted to know what is the functionality of this particular conduit.
