AbenezerWudenhe
4 years agoUnable to synthesis FPGA executable using DPC++
I am attepting to synthesis a FPGA execuitble for convolution using the A10 OneAPI FPGA Node/ It seems that I am unable to synthesis this project at it's current size. I have tried emulati...
BoonBengT_Altera
Moderator
4 years agoHi @AbenezerWudenhe,
The first qsub mention which are tyring on the node 's001-n085' which is offline, hence suspected the error seen. (i.e. you can check on the nodes availabilities by the command 'pbsnodes')
The second qsub seems to be routed to some invalid nodes as well, would suggest to check on the nodes per the list.
Quick check did you managed to check on the mention qsub above, is there any error?
Hope to hear from you soon.
Best Wishes
BB
