JasperW99
5 years agoUnable to run on FPGA hardware (Error enumerating AFCs: not found)
I've tried to follow numerous DPC++ tutorials to run code on the FPGA hardware, but everytime it seems to fail. I have seen other posts on this forum regarding the same issue, but there doesn't seem ...
EBERLAZARE_I_Intel
5 years agoHi,
Could you check the document here mentioned your possible issue:
If you are unable to build and execute the simulator, it is likely that you did not install your RTL simulation tool properly.
When you try to build and run the software, if you see an "Error enumerating AFCs" message, you omitted setting USE_ASE=1 on the make command line. The software is searching for a physical FPGA device. To recover, repeat the steps from the make clean command.
You may need to repeat the steps from the make clean command:
