BDE00
6 years agoUnable to read frequency in Cycloen10LP IOs from design circuit, same is working fine when signal generator is using.
One of my project, i am using Cyclone 10LP, due to obsolete of cyclone first gen, i am using 10LP for reading frequency, Problem is : I am not able to read frequency when IO is connected to proven c...
YuanLi_S_Intel
6 years agoHi Balakrishna,
may i know what is the configuration you use? If you are using active serial configuration, delay doesn't affect it as the FPGA will get the bitstream from flash and do the programming.
Thank You.
