DeusMMJr
7 years agoUnable to generate .gbs files with packager, seems broken. How can I deal with this issue?
I'm trying to test my AFU in FPGA node but I need the .gbs file that was not generated by compilation. So, I need to use packager to generate .gbs but packager doesn't work...
DeusMMJr
7 years agoHi @JeyanthN_Intel , really I check an incompatibility between envirnoment and FPGA FIM. I will recommend changes because I haven't permission. I think that you can close this case. Thanks !
