DeusMMJr
7 years agoUnable to generate .gbs files with packager, seems broken. How can I deal with this issue?
I'm trying to test my AFU in FPGA node but I need the .gbs file that was not generated by compilation. So, I need to use packager to generate .gbs but packager doesn't work...
Nathan_B_Intel
7 years agoHi,
Can you provide some additional information to help with the debug?
- What PAC and Acceleration Stack version are you using
- What is the exact error case you are seeing with Packager? Can you share the output of the command?
- What is meant by ".gbs file that was not generated by compilation" - are you saying that compilation of the AFU using the recommended flow failed? If so, packager won't be much help
