Unable to Compile OpenCL on Arria 10 GX
- 7 years ago
Sometimes, OpenCL kernel compilation fails during the hardware generation stage because the design fails to meet fitting constraints.
In this case, recompile the kernel using the -high-effort option of the aoc command. When kernel compilation fails because of a fitting constraint problem, the Intel® FPGA SDK for OpenCL™ Offline Compiler displays the following error message:
Error: Kernel fit error, recommend using -high-effort.
Error: Cannot fit kernel(s) on device
To overcome this problem, recompile your kernel by invoking the following command:
aoc -high-effort <your_kernel_filename>.cl
After you invoke the command, the offline compiler displays the following message:
High-effort hardware generation selected, compile time may increase significantly.
The offline compiler will make three attempts to recompile your kernel and generate hardware. Modify your kernel if compilation still fails after the -high-effort attempt.
Hope this might help.
Thank you
Your design is too large to fit on the device; i.e. it requires more resources than there are available on the device. Check the HTML report for an estimation of your design's area usage and modify your design accordingly. The "-high-effort" option will very rarely help, and only in cases where your design narrowly fails to fit on the device or route.
