MAlif1's avatar
MAlif1
7 years ago
Unable to Compile OpenCL on Arria 10 GX
Hello, I am running OpenCL kernel on Arria 10 GX board. I am not able to compile my design due to this error: Error: Kernel fit error, recommend using -high-effort. Error: Cannot fit kernel(s) on...
  • FawazJ_Altera's avatar
    7 years ago
    Sometimes, OpenCL kernel compilation fails during the hardware generation stage because the design fails to meet fitting constraints.
    In this case, recompile the kernel using the -high-effort option of the aoc command. When kernel compilation fails because of a fitting constraint problem, the Intel® FPGA SDK for OpenCL™ Offline Compiler displays the following error message:
    Error: Cannot fit kernel(s) on device
    To overcome this problem, recompile your kernel by invoking the following command:
    aoc -high-effort <your_kernel_filename>.cl
    After you invoke the command, the offline compiler displays the following message:
    High-effort hardware generation selected, compile time may increase significantly.
    The offline compiler will make three attempts to recompile your kernel and generate hardware. Modify your kernel if compilation still fails after the -high-effort attempt.
    Hope this might help.
    Thank you
