Tutorial sources location
Hello, where sources for "AN 717: Nios II Gen2 Hardware Development Tutorial" can be found? Tutorial instructs to download it form intel web site.
- KennyT_altera
I will attached the file in below.
- KennyT_altera
- anna6
TY Kenny. I am looking for design files mentioned on p 8 of AN717 that you attached which says "Locate the zipped design files on the web site"
- KennyT_altera
Seems like I cannot find it either for now, is that fine that you use this https://community.intel.com/t5/FPGA-Wiki/Qsys-Pro-Embedded-One-Stop-Solution/ta-p/736014 as temporally? I will get our factory to fix the problem.
- KennyT_altera
Is there further question?
- KennyT_altera
Btw, this is another design example you can try. https://www.intel.com/content/dam/altera-www/global/en_US/uploads/3/38/Nios_II_Hello_World_A10.pdf
- KennyT_altera
Not sure if you have further question? If no, we shall close this thread.
- KennyT_altera
As we do not receive any response from you on the previous answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
- anna6
Question can be closed. I also learned that sources for Arria 10 not available for this AN, only Cyclone
