mhm00
6 years agoTRANSCEIVER REFERENCE CLOCK INPUT IN CYCLONE V
Hi, I'm using Cyclone V GX 5CGXFC5C6F23I7N FPGA. 1) For 3.125Gbps data rate what could be the Frequency for REFCLK input in Transceiver section. 2) Which IO standard should i use for REFCLK. 3...
mhm00
6 years agoHI,
I found the solution for Question No.3. answer was in the cyclone v datasheet Transceiver Performance Specifications.
Termination for Refclk is 100 ohm,and it is On chip termination.
for detail information go through the attached file.
