The option of aoc 17.1.1 "-fast-compile" cannot work well on Intel pac_a10 board (Intel Harp)
Can you post the full quartus_sh_compile.log file? You might have some space/permission issue though since it seems "hardware generation" is finishing successfully but some error happens when writing the final logs/reports.
Sure. Actually the quartus_sh_compile.log does not contain any errors. The error messages only are shown on the screen:
"Compiling for FPGA. This process may take a long time, please be patient.
aoc: Hardware generation completed successfully.
Error: Could not open afu_opencl_kernel.fit.rpt for reading.
I recompiled them for both task and NDRange versions and they showed the same errors above. Please see the attached log files. I changed their names by adding a suffix "ndrange" and "task", respectively.
Thanks!
- HRZ7 years ago
Indeed the logs do not show any errors. If you get that error reliably every time you try to use fast-compile on the Harp Machine, it is possible that fast-compile is not supported there. Maybe one of the Intel-affiliated moderators can weigh in on this.
- hiratz7 years ago
Yea, I guess so too. I will ask them later. Thanks!
