Tensor libraries in C/C++ compatible with HLS
Hello Intel Community,
I am working on a project that is porting a neural network written in pytorch into C so that it can be modified/optimized and then put on an FPGA. My current approach is just rewriting the code base in C, however, the functions relating to Tensors are not easy to understand or re-implement. There are very few libraries that implement tensor functions (multiplication, min, max, mean, view) in C (Xtensor, Libtorch, Eigen) and none that are supported by the HLS compiler.
Before writing my own, I wanted to post here to see if any work like this had already been done or if I am missing a compatible or builtin library.
Note: I am not familiar with the industry as this is for student research.
- BoonBengT_Altera
Moderator
- messn036
I was hoping to find a library that doesnt use dynamic memory location so that it would work out of the box with the intel HLS compiler. I ended up writing my own, though the matrix_mult function from intel's extended math library did help.
- BoonBengT_Altera
Moderator
Hi @messn036,
Good day, just checking in to see if there is any further doubts in regards to this matter.
Hope we have clarify your doubts.Best Wishes
BB - BoonBengT_Altera
Moderator
Hi @messn036,
Greetings, as we do not receive any further clarification on what is provided. Hence thread will now be transitioned to community support for further help on doubts in this thread. Pleasure having you here.
Best Wishes
BB
