GBies
7 years agoSystemConsole.designLoad does not work in MATLAB
Hi, I'm using system console with Matlab and everything works, except SystemConsole.designLoad command. I have to load file manually with quartus before matlab procedures. I issue a command: Syste...
CheepinC_altera
7 years agoHi Grzegorz,
As I understand it, you are observing some issue with the design load when using system console in Matlab. Based on your observation, seems like default path in Matlab have default directory of DSP builder added. Also, the "\\" seems to be missing from the path as well. As a workaround, can you try to place your file.sof into the dsp_builder installation directory to see it works.
