Vamsi_21
3 years agoSystem console giving up
Hi, I am using intel hls compiler and generated a design to add 4 numbers. I created a .cpp file emulated it and verified the output, I created the ip file using the hls commands and have integrated...
- 2 years ago
I notice that you haven't assign any pin in pin planner. After assigning those pins, the error gone.
Sheng
ShengN_altera
2 years agoHi,
The tcl scripts I used are same with yours one. May be try power cycle the board by turn off and on?
Sheng
Vamsi_21
2 years agoHi,
I have turned off and turned on the board and tested it but still the same error is there.
