Vamsi_21
3 years agoSystem console giving up
Hi, I am using intel hls compiler and generated a design to add 4 numbers. I created a .cpp file emulated it and verified the output, I created the ip file using the hls commands and have integrated...
- 2 years ago
I notice that you haven't assign any pin in pin planner. After assigning those pins, the error gone.
Sheng
ShengN_altera
2 years agoHi,
I try again with your original design without the claim_service and it worked as well.
Does your jtag cable got any problem? May be try to reconnect and see.
Do you program the correct device id 10AX115S2?
Sheng
Vamsi_21
2 years agoHi,
I have reconnected the jtag cable and programmed the device but still there is same error, i don't think there is any problem with jtag because previously i have programmed different designs through jtag for the same device.
NAME: Arria10 Development board
Device:10AX115S2F45I1SG
Can you share the .tcl files which you have used to test the board.
