Support for GPU and FPGA programming
Hi Chao,
I am assuming that you want to implement your code parallelly on iGPU and fpga_emulator.
Please find the below code sample which will run a simple vector add on iGPU and fpga_emulator.
#include <iostream> #include <CL/sycl.hpp> #include <CL/sycl/intel/fpga_extensions.hpp> #define N 10 int main(int, char**) { float *d1_a=(float *)malloc(N*sizeof(float)); float *d1_b=(float *)malloc(N*sizeof(float)); float *d1_c=(float *)malloc(N*sizeof(float)); float *d2_a=(float *)malloc(N*sizeof(float)); float *d2_b=(float *)malloc(N*sizeof(float)); float *d2_c=(float *)malloc(N*sizeof(float)); for(long int i=0;i<N;i++){ d1_a[i]=i; d1_b[i]=N-i; d2_a[i]=i; d2_b[i]=N-i; } auto exception_handler = [] (cl::sycl::exception_list exceptions) { for (std::exception_ptr const& e : exceptions) { try { std::rethrow_exception(e); } catch(cl::sycl::exception const& e) { std::cout << "Caught asynchronous SYCL exception:\n"<< e.what() << std::endl; } } }; cl::sycl::queue queue_d1(cl::sycl::gpu_selector{}, exception_handler); cl::sycl::queue queue_d2(cl::sycl::intel::fpga_emulator_selector{}, exception_handler); /*std::cout << "Running on " << queue_d2.get_device().get_info<cl::sycl::info::device::name>() << "\n"; */ { cl::sycl::buffer<float, 1> d1_a_sycl{d1_a, cl::sycl::range<1>{N} }; cl::sycl::buffer<float, 1> d1_b_sycl{d1_b, cl::sycl::range<1>{N} }; cl::sycl::buffer<float, 1> d1_c_sycl{d1_c, cl::sycl::range<1>{N} }; cl::sycl::buffer<float, 1> d2_a_sycl{d2_a, cl::sycl::range<1>{N} }; cl::sycl::buffer<float, 1> d2_b_sycl{d2_b, cl::sycl::range<1>{N} }; cl::sycl::buffer<float, 1> d2_c_sycl{d2_c, cl::sycl::range<1>{N} }; queue_d1.submit([&] (cl::sycl::handler& cgh) { auto a_acc = d1_a_sycl.get_access<cl::sycl::access::mode::read>(cgh); auto b_acc = d1_b_sycl.get_access<cl::sycl::access::mode::read>(cgh); auto c_acc = d1_c_sycl.get_access<cl::sycl::access::mode::discard_write>(cgh); cgh.parallel_for<class vector_addition_d1>(cl::sycl::range<1>{ N }, [=](cl::sycl::id<1> idx) { c_acc[idx] = a_acc[idx] + b_acc[idx]; }); }); queue_d2.submit([&] (cl::sycl::handler& cgh) { auto a_acc = d2_a_sycl.get_access<cl::sycl::access::mode::read>(cgh); auto b_acc = d2_b_sycl.get_access<cl::sycl::access::mode::read>(cgh); auto c_acc = d2_c_sycl.get_access<cl::sycl::access::mode::discard_write>(cgh); cgh.parallel_for<class vector_addition_d2>(cl::sycl::range<1>{ N }, [=](cl::sycl::id<1> idx) { c_acc[idx] = a_acc[idx] + b_acc[idx]; }); }); } try { queue_d1.wait_and_throw(); queue_d2.wait_and_throw(); }catch (cl::sycl::exception const& e) { std::cout << "Caught synchronous SYCL exception:\n"<< e.what() << std::endl; } for(int i=0;i<N;i++) std::cout<<d1_c[i]<<" "; std::cout<<std::endl; for(long int i=0;i<N;i++) std::cout<<d2_c[i]<<" "; std::cout<<std::endl; return 0; }
You can change the device selector according to your use-case.
Warm Regards,
Abhishek
- Gao__Chao6 years ago
I already did this before, I am actually looking for a solution for using GPU and FPGA instead of just emulator.
the problem I am now facing is I can't compile the file, you see that GPU and FPGA need two different compile instruction in makefile.
I didn't find any workflow that intel example, I suppose you can use one file to make CPU, FPGA and GPU works in parallel?
For example, I want to partition one matrix to three part and do three partial multiple in CPU, GPU, FPGA within one node, is this possible?
Chao
