Pan
6 years agoSummary data invalid in HTML report.
Hi. Above I mentioned error which sometimes happens after cosimulation or compilation is done (using Makefile). Usually, the problem occurs when an already existing cosimulation or compilation folde...
MEIYAN_L_Intel
6 years agoHi,
If you have encounter the same problem, you can upload the file here so that we can further more investigating and debugging the problem.
Also, if you are facing any problem that is different from this problem, I would like to suggest to open another new forum for better support.
