Pan
6 years agoSummary data invalid in HTML report.
Hi. Above I mentioned error which sometimes happens after cosimulation or compilation is done (using Makefile). Usually, the problem occurs when an already existing cosimulation or compilation folde...
Pan
6 years agoI am really sorry. Now I see the topic has been set to High Level Design and not to High Level Synthesis. I apologize for my mistake and I will repost the question with the topic properly set, since I don't see an option to delete High Level Design topic. Thank you for your response.
HRZ
6 years agoThere is no "High Level Synthesis" forum; the High Level Desin forum is for High Level Synthesis, OpenCl, etc. You are likely in the right place. Can you archive and attach an example of such corrupted HTML report?
