UTech
7 years agoStuck with alt_sld_fab file related error while generating GBS file for AFU
Hi, I have created an AFU setup integrated with CCIP, Memory(DDR) and MAC. Currently I'm stuck at synthesis phase of GBS file generation(I'm adding .qip and .ip files in filelist.txt). I''m seeing ...
JohnT_Altera
7 years agoHi,
Could you try to compile using Acceleration Stack 1.2? You should be able to upgrade your board with this version as well.
- UTech7 years ago
Sure, I will try with Acceleration Stack 1.2
