hbens
6 years agoStreaming data between RTL module and OpenCL kernel using Avalon ST interface
Hi, I'm trying to to use Avalon ST interface to stream data between an OpenCL kernel and RTL module. The avalon ST interface stream data always when ovalid=1 and oready =1 as mentioned in the first...
AnilErinch_A_Intel
6 years agoHi
Sorry for the late answer,
It turns out that If you have declared your RTL as stall free component this scenario can occur, can you share the .XML file in which you have defined the properties of the RTL module.
Thanks and Regards
Anil
