stream_in memory type
Morten,
Do you mind if you share your code here? Could be useful for analysis
If you are using the ihc::depth parameter with a stream, and accessing it using tryRead(), there is a known issue described in the link below: Intel High Level Synthesis Compiler Pro Edition: Best Practices Guide
Unfortunately I cannot share the code as is. I would have to write a test using the same stream, but that is not on my priority list right now. As long as 17.1 compiler can build this, I have a way out.
Note:This is not the simulation not working. It is the RTL that stops working. C simulation works fine. I have not simulated RTL in modelsim cause I dont have the right testbench for that type of simulating (I draw the results visually using windows gdi, not comparing numbers)..
