Hossam1
5 years agoSorting algorithm
I need help with my assignment:
How to make a sorting algorithm that will sort 5-8 4bits numbers, using Quartus and the Modelsim program?
Thank you in advance for your help
1 Reply
- Hazlina_R_Intel
Contributor
Thanks for your question. Have you checked out the internet resources through any web search engine for the potential example codes that you can use to build your program?
You may use the key word of "sorting algorithm using verilog" and you may find some example codes that you may use.
-Hazlina
