Some problems happened when try example of hls
Dear all
I am a starter for hls,
I have some problems, when I try this example "counter" as ug-hls-getting-started.
I am using VS2010 professional and Quartus 18.1 lite.
I don't know where is wrong.
Thanks for your support!
The detail information as below:
C:\intelFPGA_lite\18.1\hls\examples\counter>build.bat test-x86-64
i++ -march=x86-64 counter.cpp -o test-x86-64.exe
msvcrt.lib(crtexe.obj) : error LNK2019: unresolved external symbol __imp_Sleep referenced in function __tmainCRTStartup
msvcrt.lib(crtexe.obj) : error LNK2019: unresolved external symbol __imp_EncodePointer referenced in function pre_c_init
msvcrt.lib(atonexit.obj) : error LNK2001: unresolved external symbol __imp_EncodePointer
msvcrt.lib(unhandld.obj) : error LNK2019: unresolved external symbol __imp_SetUnhandledExceptionFilter referenced in function __CxxSetUnhandledExceptionFilter
msvcrt.lib(atonexit.obj) : error LNK2019: unresolved external symbol __imp_DecodePointer referenced in function _onexit
msvcrt.lib(gs_support.obj) : error LNK2019: unresolved external symbol __imp_QueryPerformanceCounter referenced in function __security_init_cookie
msvcrt.lib(gs_support.obj) : error LNK2019: unresolved external symbol __imp_GetTickCount referenced in function __security_init_cookie
msvcrt.lib(gs_support.obj) : error LNK2019: unresolved external symbol __imp_GetCurrentThreadId referenced in function __security_init_cookie
msvcrt.lib(gs_support.obj) : error LNK2019: unresolved external symbol __imp_GetCurrentProcessId referenced in function __security_init_cookie
msvcrt.lib(gs_support.obj) : error LNK2019: unresolved external symbol __imp_GetSystemTimeAsFileTime referenced in function __security_init_cookie
test-x86-64.exe : fatal error LNK1120: 9 unresolved externals
HLS Link x86-64 FAILED.
Run test-x86-64.exe to execute the test.
- MuhammadAr_U_Intel
Contributor
It seems like you are missing the linking of libraries for VS. Did you run initialization script prior to running compilation ? https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/ug-hls-getting-started.pdf Page 8 • On Windows systems, initialize your environment as follows: a. In your command prompt session, change directories to the hls directory in your Intel Quartus Prime installation directory. For example, C:\intelFPGA_pro\18.1\hls b. Run the following command from the hls directory to set the environment variables for the i++ command in the current terminal session: init_hls.bat The command prints out the modified environment variable settings. The environment initialization script shows the environment variables that it set, and you can now run the i++ command from this command prompt session.- jjl3
Yes, I did as the document hls/ug-hls-getting-started.pdf
C:\intelFPGA_lite\18.1\hls\examples\counter>init_hls.bat
Assuming current directory (C:\intelFPGA_lite\18.1\hls\) is root of i++
Will use C:\intelFPGA_lite\18.1\hls\..\quartus to find Quartus for internal i++ use
Quartus at C:\intelFPGA_lite\18.1\quartus\bin64\ will be used for any direct use
Will be using Modelsim at C:\modeltech64_10.7c\win64\
Adding C:\intelFPGA_lite\18.1\hls\bin to PATH
Adding C:\intelFPGA_lite\18.1\hls\host\windows64\bin to PATH
Contributor
Its hard to guess, do you have multiple versions of Visual Studio installed ? "If you have multiple versions of Visual Studio, Microsoft recommends installing Visual Studio versions in the order in which the versions were released. For example, install Visual Studio 2010 before installing Visual Studio 2015. For details, see Install Visual Studio Versions Side-by-Side in the MSDN Library" Or perhaps try on a different machine, with a fresh installation of Visual Studio/ Quartus Prime Lite. thanks, Arslan
