TLeng2
7 years ago[solved] Arria 10 HPS OpenCL Compile problem, no hps_isw_handoff folder HPS Opencl host, SD Boot
Hello Guys and Girls, I am working on a small project with an Arria 10 SOC Dev Kit from dreamchip. I got the Board package for the SD card build with the edits for compiling to run an openCL compil...
TLeng2
7 years agoHello @FJumaah ,
It is a QSYS with HPS,
i got the isw_handoff folder when i send the command aoc blank.cl --bsp-flow=base
I took also the xml files from the ghrd, ( only 2 existing ...Base_board and ...common_board )
at the moment i have still some troubles. i got it working to full boot from sd card but in DTS / DTB built i had errors about base_iopll node.
I booted the system and installed the kernel module which died with an Kernelpanic ii checked the BSP and I found out that one IP file in the BSP was ipbackup not ip. i changed it and now its running.
Still have the u-boot panic when i try network related commands but hey it boots from SD now fully.
Testing more....
Thank You :-)
