Simualte HLS IP with Qsys
If adding a HLS-generated IP to a qsys project, how to simulate the qsys project with Modelsim-Altera?
- aikeu
Hi BigHandsomeBee,
You can find the details regarding simulation with of HLS using modelsim in the following link under chapter 6:
Aik Eu
- BigHandsomeBee
This does not answer my question.
My question is after integrating the HLS IP inside a Qsys project, how to simulate the project.
- aikeu
- aikeu
Hi BigHandsomeBee,
Sorry that I may not fully understand your question, can share more details about it? In chapter 6 of the document, it mentioned the process of verifying Your IP with simulation using modelsim. I can try to provide more info from your feedback.
Aik Eu
- BigHandsomeBee
Thanks for the reply.
I'm not asking how to simulate HLS IP.
What I'm trying to do is that, I have a verified HLS IP, and I need to integrate this IP into a Qsys project, connecting it with other component/IPs, to build a project.
After building the Qsys project, I need to run the simulation to verify the project.
Then I need to use ModelSim to simulate the project.
But when simulating with ModelSim, it complains that the HLS IP module cannot be resolved, which means, I guess, I need to compile the instantiated HLS IP into a library before simulating the Qsys project with ModelSim.
But I don't know how to do that.
- aikeu
Hi BigHandsomeBee,
May I know how you managed to generate simulation files in qsys but when opening up with modelsim, there is error?
Can share us the logs of the error?
Aik Eu
- aikeu
- aikeu
Hi BigHandsomeBee,
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Aik Eu
