Sample project with RTL module library not working
- 4 years ago
The issue is in my expHBU.h file. I put
uint8_t expHBU(uint8_t input);Rather than the CORRECT
extern "C" { uint8_t expHBU(uint8_t input); }This extern is extremely esoteric and should be included in the reference manual.
Hello messn036,
Thank you for sharing the failure log with us.
I think the simple design is necessary to investigate it for us.
So could you share simple full design which can duplicate the error with us?
Yoshiaki Saito
Here are the source files I am using. I am trying to model the basic rtl library tutorial the best I can (which compiles fine in my environment). I'm sure its some easy syntax error that none of the compilers or packagers is catching.
I cannot upload the .cpp and .h files because this site rejects them. Here is the source
expHBU.h
#include <stdint.h> #include "HLS/math.h" uint8_t expHBU(uint8_t input);
expHBU.cpp
#include "expHBU.h" uint8_t expHBU(uint8_t input){ return (uint8_t)exp(input); }
component_testbench.cpp
#include "HLS/hls.h" #include "HLS/stdio.h" #include "HLS/math.h" #include "expHBU.h" component uint8_t executeexp(uint8_t exponent) { return expHBU(exponent); } component uint8_t executeexp_basic(uint8_t exponent) { return exp(exponent); } int main() { uint8_t exponent = 3; uint8_t result = executeexp(exponent); printf("result %d \n", result); return 0; }
Reminder: the x86 simulation works, but the FPGA compile does NOT
messn036
- messn0364 years ago
- YoshiakiS_Altera4 years ago
Hello messn036,
Thank you for the update.
Basically, you need to add the extern “C” to call a function from C++ to C. This is general rule of C++.
C++ Language adds a prefix to a function name to support the class feature.
But, this feature is disabled when you add extern “C”.
So many C/C++ headers include:
#ifdef __cplusplus extern "C" { #endif rtl_inet_uint16 rtl_htons(rtl_inet_uint16 hostshort); rtl_inet_uint16 rtl_ntohs(rtl_inet_uint16 netshort); rtl_inet_uint32 rtl_htonl(rtl_inet_uint32 hostlong); rtl_inet_uint32 rtl_ntohl(rtl_inet_uint32 netlong); #ifdef __cplusplus } #endifBest regards,
Yoshiaki Saito
Hello messn036,
I will close this thread if no further questions from you.
Yoshiaki Saito
