whan01's avatar
whan01
7 years ago
Running HARP example design returns error value -54.
I modify the host code of example design.
The original part in launching the first kernel is
status = clEnqueueNDRangeKernel(queue, kernel, 1, NULL, gsize, lsize, 0, NULL, NULL)
I modify this part to
// define NDRange Size
size_t gsize[1]={(size_t) 10};
size_t lsize[1] = {(size_t) 2};
Then I run the code it returns error code -54. Why can't I increase the 1-d lsize to 2?
  • Is there any reqd_work_group_size or max_work_group_size used in the kernel?
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    May I know the software version and edition you are using? Could you share the error message and provide the design for investigation?
    • whan01's avatar
      whan01
      The software is quartus 16.0.2 pro with all update patches installed. My OpenCL is v2.0.
  • HRZ's avatar
    HRZ
    • whan01's avatar
      whan01
      You remind me. There's neither reqd_work_group_size nor max_work_group_size, but at the head of each kernel function there's a declaration __attribute__((task)) which implicitly indicates the max work group dimension is 0. The max group work items is 1. So here's problem. Thanks!
      • HRZ's avatar
        HRZ
        So the kernel is not even NDRange. 😅
        Be careful that just removing that attribute will not convert the kernel to NDRange; you will need to rewrite the kernel and replace the loops in it with get_global_id()/get_local_id().
