STATEABC
2 years agoRunning dla_build_example_design.py failed and no .sof file was generated
My system is 20.04, FPGA AI Suite version is 2024.1, OpenVINO version is 2023.3, Quartus version is 23.4 I generated an optimized genarate_arch.arch file by running the dla_compiler command. Its bas...
JohnT_Altera
2 years agoHi,
I try to follow the step you provided and compile from my side and I do not observed the issue. Can you provide the full compilation log so that I can fully look into the issue?
