STATEABC
2 years agoRunning dla_build_example_design.py failed and no .sof file was generated
My system is 20.04, FPGA AI Suite version is 2024.1, OpenVINO version is 2023.3, Quartus version is 23.4 I generated an optimized genarate_arch.arch file by running the dla_compiler command. Its bas...
JohnT_Altera
2 years agoHi,
Can you provide me the step by step method that you use to run it? Can you share with me the input file so that I can try to see if I am able to duplicate the issue?
STATEABC
2 years agoOf course
After activating the environment variables according to the FPGA AI Suite: Getting Started Guide, I ran
dla_build_example_design.py -ed 3 -n 1 -a AGX7_Performance --build-dir build_path --build --output-dir ouuput_path
